member access
spunky banter
Posted 2005-01-20 12:48 AM (#165981)
Subject: member access
Here's another fine mess I've gotten myself into. I'm having trouble getting into the member access area. I log in and it indicates that I'm not logged in. I hit 'register' to see what happens. Screen tells me I'm already registered and am currently logged in. So, I hit 'member access' and it tells me to login or register. I tried the 'remove cookies' remedy but to no avail. Can someone help
Nils
Posted 2005-01-20 12:52 AM (#165982 - in reply to #165981)
Subject: Re: member access
Just a guess, but did you try logging out & then logging back in?
Posted 2005-01-20 2:02 AM (#165983 - in reply to #165981)
This use to happen to me.
Try typing in the "WWW" at the first of the address and see if this helps. When I was having problems, I just typed the site name without the "wwww". Couldn't see the gallery menus, members area, or anything other than the message board.
Stephen
willard
Posted 2005-01-20 5:08 AM (#165984 - in reply to #165981)
Check to be sure your browser is accepting cookies.
cruster
Posted 2005-01-20 5:56 AM (#165985 - in reply to #165981)
But stay away from the brownies. There's something...not right about them.
willard
Posted 2005-01-20 7:31 AM (#165986 - in reply to #165981)
The brownies were just the gateway. We're way beyond them now.
spunky banter
Posted 2005-01-20 8:33 AM (#165987 - in reply to #165981)
Thanks for your input. I tried Stephen's solution and it worked. I'm feeling much better now. :)
Spunky
Pappa Bear
Posted 2005-01-20 9:53 AM (#165988 - in reply to #165981)
Spunky,
I'm glad you posted that question. I have had that problem with my 'puter at work, but now I can access it using the "WWW" trick.
Thanks for the solution Stephent28!!!
Kindest Regards,
Anthony
Posted 2005-01-20 10:30 AM (#165989 - in reply to #165981)
Well, not to take all the credit but the solution came to me during a conversation I was having with Tony Calman a few weeks ago.....
so credit where it is due....THANKS TONY :D
Stephen
