Op Pro Problems?
willard
Posted 2004-06-13 4:40 PM (#185253)
Subject: Op Pro Problems?
Seems like I remember some complaints about the necessary volume levels on the Op-Pro preamp. I never heard any resolutions. Are there some bugs with the new system or were there just some problems on a few guitars that the volume needed to be turned way up to acheive similar levels as other preamps?
Posted 2004-06-13 5:17 PM (#185254 - in reply to #185253)
Subject: Re: Op Pro Problems?
Bill, unless there is a specific fault in a specific preamp, most preamp-equipped professional instruments, regadless of make, will put out a pretty consistent line-level signal. I would suggest that anything else is user-error.
CharlieB
Posted 2004-06-13 6:51 PM (#185255 - in reply to #185253)
January 2004
I think you'll find it has more volume than say... a Les Paul.
Keeping the volume level up is good - better signal to noise ratio in the cable, less high frequency rolloff.
willard
Posted 2004-06-13 7:28 PM (#185256 - in reply to #185253)
I just thought I remembered several people saying that they were haveing problems and never heard the end of it.
mccullpl
Posted 2004-06-17 9:55 AM (#185257 - in reply to #185253)
I was one of those people. I still think the output is less than my wife's Dean acoustic, but i compared it to my friend older Standard Elite, and the output between my new Std. elite LX and his Std. Elite were pretty much the same. I guess I'd say there isn't an issue...
willard
Posted 2004-06-17 12:53 PM (#185258 - in reply to #185253)
Thanks for the reply. That's exactly what I was looking for. I'm glad it worked out.
John B
Posted 2004-06-17 12:59 PM (#185259 - in reply to #185253)
January 2004
I have noticed the same thing with my OP Pro. I find that the knob is much less sensitve and adjusts the volume much more gradually than the pre-amps on my other O's. I find this to be a good thing because it makes it easier to fine tune the sound. All in all, I'm very happy with the OP-pro except for the fact that the sound doesn't mute during tuning.
zchord
Posted 2004-06-17 9:43 PM (#185260 - in reply to #185253)
I played my OP-Pro equipped LX out tonight and had the volume knob on nine and my channel on the board was really hot, only reasonably loud, but enough volume. It is at max potential, though. With my amp, same problem. I have to trn it all the way to get reasonable volume. The signal is very weak. A lot weaker than my passive Fishman pickups at the same level on the amp. Something is not right.
RobT
Posted 2004-06-18 7:32 AM (#185261 - in reply to #185253)
I have connected my LX wiht OP Pro to three different amplifiers and have had no problem...no problem with volume at all...it's plenty loud.
