High E buzz; Mothership question
Jukebox Joe
Posted 2009-09-22 11:49 AM (#397315)
Subject: High E buzz; Mothership question
August 2009
Howdy all. My favorite git (my lusty red 1778T :o ) has developed a buzz on the high E string even when I raise the action with a truss adjustment (no shims are removed). I assume this is due to a worn down slot in the nut or bridge. Does this sound right?
If so, who would be the appropriate repair person? Myself? Any luthier? The mothership?
Thanks!
AussieJames
Posted 2009-09-23 5:25 AM (#397316 - in reply to #397315)
Subject: Re: High E buzz; Mothership question
June 2007
At what fret is it buzzing?
Have you checked the height of the strings at the nut?
What neck relief do you have?
AJ
twistedlim
Posted 2009-09-23 7:02 AM (#397317 - in reply to #397315)
November 2008
Does it buzz open or fretted or both?
Jukebox Joe
Posted 2009-09-23 7:09 AM (#397318 - in reply to #397315)
August 2009
Sorry, I should have specified: it buzzes open, not fretted.
AussieJames
Posted 2009-09-23 7:35 AM (#397319 - in reply to #397315)
June 2007
So if you fret it up the deck at what fret does it stop buzzing?
If you fret the string between the second and third how much clearance do you have at the first?
We have to start somewhere
AJ
twistedlim
Posted 2009-09-23 7:55 AM (#397320 - in reply to #397315)
November 2008
If it does not buzz when you fret it is probably the nut. It wears down after a while. About $40 will get a new one made from a competent luthier.
GaryB
Posted 2009-09-23 8:32 AM (#397321 - in reply to #397315)
August 2007
Find a good guitar tech in your area. They can pinpoint a problem like that in minutes. Can really be one of many things. Loose fret, uneven fret, bad string.
A good guitar guy will raise the bar on what you come to expect from your guitar; and generally an annual visit, or so, will take care of a lot of ills, including normal climate variations.
Jukebox Joe
Posted 2009-09-23 8:44 AM (#397322 - in reply to #397315)
August 2009
It stops buzzing right at the first fret. It's only when it's open that it buzzes. I'll take it to a guitar guy that I know. Aussie, I'll check that out tonight.
Thanks, guys!
Posted 2009-09-23 9:54 AM (#397323 - in reply to #397315)
You can fill the Nut slot with either a Porcelin repair or Nail Polish and then refile the groove. Most likely the groove is too wide on the FB side.
Getting to know your Tech is a must!
