Using soundhole pickup on an Ovation...
nosajwp
Posted 2008-01-02 12:51 PM (#448509)
Subject: Using soundhole pickup on an Ovation...
Does anyone here use a magnetic soundhole pickup in addition to, or instead of, the pickup/preamp in their Ovation?
If you do, which one do you use and why? What do you run it through before it gets amplified, and how does it sound?
Posted 2008-01-02 1:05 PM (#448510 - in reply to #448509)
Subject: Re: Using soundhole pickup on an Ovation...
I bought a Bill Lawrence sound hole pickup a couple years ago for my Matrix, which doesn't have a preamp. It worked fine, except that it totally failed it's primary function of keeping me from buying other guitars. I just quit using it or the Matrix much and I don't use an amplifier much.
I liked how it worked and the ease of attaching it to the soundhole, except it didn't quite fit well with the Ovation rosette.
Mitchrx
Posted 2008-01-02 1:19 PM (#448511 - in reply to #448509)
Those old Bill Lawrence p/u's were very good. I had one years ago and the only issue is that because it is magnetic, the B string is a lot louder than the G string. I used to keep a small pice of electrical tape on the areas of the B string which balanced it a bit, but not perfect. I saw Leo Kottke back in the 70's and he used the deluxe model in the soundhole and also mic'd the guitar. The combination had a really full sound.
Posted 2008-01-02 1:52 PM (#448512 - in reply to #448509)
I have a Fishman Neo-D in my Folklore. Works OK.
Contact Kim or John at Ovation. A thinline undersaddle pickup is under $50. Would be a better choice. The saddle slot on my Folklore wasn't long enough for one of those.
Posted 2008-01-02 3:22 PM (#448513 - in reply to #448509)
K&K "western" or Fishman "Blend RareEarth"
Posted 2008-01-02 3:57 PM (#448514 - in reply to #448509)
On Ovation, NO
On the Tak TNV460SC, yes, the tri-axe pickup that is compatable with the cool tube. Using it tonight in fact, topic is "Looking back and/or last year"
Posted 2008-01-02 3:59 PM (#448515 - in reply to #448509)
. . . make sure you play with your back to the audience . . .
nosajwp
Posted 2008-01-02 3:59 PM (#448516 - in reply to #448509)
Actually, I like the Ovation pickup in my '05 Collector. I was just thinking about adding a soundhole pickup for some different possible sounds.
Plus...I'm hoping I could use it to get some pseudo-electric tones out of it. I'd put some DR Zebras on it, and maybe I could get some sounds similar to a solidbody or semi-hollow electric.
Old Tele man
Posted 2008-01-04 6:52 PM (#448517 - in reply to #448509)
...I use an older DeArmond-Rowe humbucker in the soundhole of my big roundback '76 Balladeer and play it though my Super Reverb Amp.
sycamore
Posted 2009-02-28 3:24 PM (#448518 - in reply to #448509)
March 2007
Applause has Artec MSP50 - see my previous posts. Yes, you can get it to sound sort of electricish. See also John Campbell http://www.youtube.com/watch?v=bpI-QwiLGjk - played Gibson acoustic with soundhole via Fender amps.
Posted 2009-03-01 1:52 PM (#448519 - in reply to #448509)
I have an old Dimarzio soundhole pickup I play around with, straight into my little Rogue acoustic amp (remember, I'm the Zeitgeist of BFLG).
I'm with Mark- the little slots on the pickup body & the spring clip are too narrow for the standard Ovation rosette. Functions fine, though.
And, about keeping my back to the audience- moot point; I don't ever have one- for a multitude of reasons, actually.
