Adding a volume control
Dougbailey
Posted 2013-09-17 3:53 PM (#475066)
Subject: Adding a volume control
September 2013
Greetings. I am still looking for recommendations ... I have an old Balladeer 1112, it has a piezo under saddle wired directly to the output jack. (No preamp).
Can I add a volume control to this... If so, what control would work and what wiring schematic do I need!
Thanks
Doug
Posted 2013-09-17 8:56 PM (#475078 - in reply to #475066)
Subject: Re: Adding a volume control
Doug, welcome.
I've upgraded your membership so you can go ask in the main section. This "Welcome Center" only has a few people able allowed to respond, so you'll have a better response there.
Dougbailey
Posted 2013-09-18 10:56 AM (#475099 - in reply to #475066)
September 2013
Well I did add a volume control, except not to the guitar. I soldered a potentiometer in line to a guitar cable. It works, and without having to drill a hole for the vol control into the bowl of the Balladeer. The I noticed Taylor sells one ($60) on M F. A little price, but same effect.
Posted 2013-09-18 2:28 PM (#475112 - in reply to #475066)
Yes, I have something similar by Fishman with the addition of EQ. Glad you figured out your solution.
