gluing down rosette
bauerhillboy
Posted 2007-07-02 8:10 AM (#91843)
Subject: gluing down rosette
Working on a Std. Baladeer for a friend, and the rosette's loose. What adhesive should I use to re-attach?
John <>{
Charlie Ramon
Posted 2007-07-02 9:57 AM (#91844 - in reply to #91843)
Subject: Re: gluing down rosette
August 2004
Superglue didn't work so I used a two-component adhesive gluing a loose rosette on my Custom Legend. Worked like a charm.
Karl
Mitchrx
Posted 2007-07-02 10:37 AM (#91845 - in reply to #91843)
Even though it would work very well, I wouldn't use two-part epoxy because it is permanent. I've had good results with super glue.
Posted 2007-07-02 11:36 AM (#91846 - in reply to #91843)
I would contact the service department and ask them what THEY use. You're probably not going to get a better answer than that.
bauerhillboy
Posted 2007-07-03 10:52 AM (#91847 - in reply to #91843)
The word from Kim:
"Just use a 5 min. epoxy and clean the excess with alcohol."
