OP20 Pre-amp problems
deepblue
Posted 2010-02-27 10:54 PM (#3990)
Subject: OP20 Pre-amp problems
February 2010
hey all....looks like a cool place.
I just bought a used Ovation. Its a Celebrity
CK 047....Problem is, the electronics dont work and I have no manual to in fact check if im doing it right...The battery checker flashes, is that good or bad?
any suggestions?..Its an OP20 preamp
Posted 2010-02-28 2:13 AM (#3991 - in reply to #3990)
Subject: Re: OP20 Pre-amp problems
Welcome DB... If your battery light comes on when you press the 'Tuner' button? It is supposed to do that.
If your battery light just flashes, your battery is dying.
Have you plugged the guitar into an amp?
Anyway... When you look into the sound-hole, or reach in there, you will find two wires going to the back of the can. The little thin wire comes from the pick-up. That must be there for the tuner to work. The larger wire is to the jack, it must be there for the amp to work.
But they should both be there.
[That is inside of my CK047]
deepblue
Posted 2010-02-28 6:02 AM (#3992 - in reply to #3990)
February 2010
Thank you Arthur...
Even with a new battery the light flashes. It looks like I bought a lemon. Will I ever learn?
Posted 2010-02-28 6:30 AM (#3993 - in reply to #3990)
Here are some Manuals on file at Ovation Tribute
Just click the window that sez 'Ovation Archives' then click 'Owner's Manual'
While you are there, search around. Jerome created this and it is full of knowledge.
Plus nifty photos.
deepblue
Posted 2010-02-28 9:58 AM (#3994 - in reply to #3990)
February 2010
Arthur, thank you so much. You have been a real help to me.
Posted 2010-02-28 4:21 PM (#3995 - in reply to #3990)
welcome deepblue..
You are good to go for the main forum.
