1615 Pacemaker battery change
Markthemagic
Posted 2005-10-11 9:20 PM (#133789)
Subject: 1615 Pacemaker battery change
June 2004
Hi All,
I have been very busy(five kids under 11 you know) and unfortunately not able to follow the threads here recently, but took time to acquire this guitar after reading many of the impressions of the 1615 on this site.
It showed up today in mint condition. I was worried I paid too much, since most of these go for less on ebay, but thought if it is in the condition specified it would be worth the price.
The case is in good shape except for the trim strip which I plan to reglue back on.
It sounds great with old rusty strings so I am looking forward to hearing it with new strings, but before I did that, I thought I would ask you all for tips on battery changes.
If anyone has any good tips about battery changes in this model I would certainly appreciate them.
Thanks
Markthemagic
Posted 2005-10-11 9:23 PM (#133790 - in reply to #133789)
Subject: Re: 1615 Pacemaker battery change
June 2004
Oh I forgot to add the ebay link for anyone that wants to see pictures. Here it is:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=ADME:B:EOI...
Old Applause Owner
Posted 2005-10-11 9:29 PM (#133791 - in reply to #133789)
July 2003
Mark, check that the neck is straight before going any farther....old 12-strings have a tendency to have neck twist. I have a 1981-vintage 1118 GC 12-string that does.
I have a 1617 that probably has the same battery container that you do.....and it sure is NOT handy!!!! I've never mastered changing the battery in it (but since the pickup doesn't work, it doesn't matter).
Roger
Old Applause Owner
Posted 2005-10-11 9:34 PM (#133792 - in reply to #133789)
July 2003
Oh....and be advised that changing strings on a slothead, especially a 12-string, is an "adventure"......
Congrats...your 1615 looks pretty similar to my 1118(a picture is in my gallery).
Roger
Markthemagic
Posted 2005-10-11 9:37 PM (#133793 - in reply to #133789)
June 2004
Hi Roger,
I am not seeing any neck twist. It has a screw in the base side that appears to hold the battery holder in place. Do you remove the screw or just pull the battery out when you have the string loose or off.
Buckaroo
Posted 2005-10-11 10:29 PM (#133794 - in reply to #133789)
...."had it tested at music store and (with new battery) works perfectly...sounds like an orchestra !
Did they take out the "new battery" after they tested it? Very nice instrument. I have a feeling the tone will be vibrant with proper strings. I'm not sure why. The grain looks right and ready to sing. The guitar does not seem over priced. Enjoy it!
Posted 2005-10-12 6:40 AM (#133795 - in reply to #133789)
To remove the battery compartment, reach inside the bowl aand apply a slight pressure while turning the screw about a quarter turn, the battery compartment should release. It is attached with wires to the pickup so be careful not to pull it out too far. Remove battery and replace with the BEST BATTERY you can buy. A heavy duty alkaline. Replace compartment carefully a put on new strings and PLAY ON. :)
Posted 2005-10-12 7:57 AM (#133796 - in reply to #133789)
Just send it to me and I'll fix it. Have it back to you in a month or so! :rolleyes:
M(miss my old Pacemaker)Woody
Markthemagic
Posted 2005-10-12 8:42 AM (#133797 - in reply to #133789)
June 2004
I have not had a chance to plug it in yet. I will do that today. The battery is probably ok. It just looked like changing the battery had something to do with changing strings and figured if I was changing strings I should replace the battery.
Posted 2005-10-12 8:46 AM (#133798 - in reply to #133789)
Hopefully you'll be changing the strings more often than the battery...
Wait. Pacemaker 12 string. Maybe not...
Posted 2005-10-12 10:32 AM (#133799 - in reply to #133789)
the battery screw is only 1/4 turn. Duracell.
