UK II Bridge Adjustment
| kotadawg |
Joined: November 2007 Posts: 1486 Location: Cincinnati | I just found a UK II for a friend, but the bridge is sitting high off the body, about 1/8". Is there a problem with the bridge or is it just a question of adjustment. Thanks. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Adjustment depends on which type of bridge it has. There's the Schaller type or the original Ovation bridge. The Ovation bridge has brass saddles on a brass plate with a textured black plastic cover. The Schaller adjusts using the 2 studs on which it's mounted. The Ovation bridge also sits on threaded studs but has a third bolt ajustable from the back of the guitar. | ||
| CrimsonLake |
Joined: August 2006 Posts: 3145 Location: Marlton, NJ | I have an issue with mine as well. The pickup ring sits right up against the bridge, blocking access to the adjustment screws - making it nearly impossible to fix the intonation. The one you found probably just needs a height adjustment. | ||
| kotadawg |
Joined: November 2007 Posts: 1486 Location: Cincinnati | This is the Schaller bridge. Do I need to loosen the strings or do anything else or can i just start turning the screws? Thanks. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Originally posted by CrimsonLake: Yes, that's a major pain, but it's only a problem with the later Schaller bridge. The Ovation bridge adjusts from the other end. If you can find an original Ovation bridge, along with height adjustment studs and rear nut it's an easy job to swap them.I The pickup ring sits right up against the bridge, blocking access to the adjustment screws | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | The Schaller bridge has always looked wrong to me. The rear part seems to sit too high. If the action on the guitar is OK you might be stuck with it as it is, because lowering the bridge will also lower the action. | ||
| kotadawg |
Joined: November 2007 Posts: 1486 Location: Cincinnati | The action is a little high but I don't know if it's that high. The bridge on my UK II fits like a glove and the action is great. Amazing how 2 guitars can differ.Thanks, Paul. | ||
| BruDeV |
Joined: January 2003 Posts: 1498 Location: San Bernardino, California | Take a paper clip (the larger size) and straighten it out. Flatten one end (about 1/4 of an inch). Bend about 1/4 of an inch of the other end 90 degrees. Flatten that end (perpendicular to the shaft). Use it to adjust the intonation from above. It's a lot easier. Before you adjust the bridge make sure the neck is setting in the pocket correctly. It might be loose or have a spacer between the neck and body. | ||
| Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | What's intonation? | ||
| moody, p.i. |
Joined: March 2002 Posts: 15678 Location: SoCal | Originally posted by Beal: A string you can't get to tune. Don't worry about it.....What's intonation? | ||
| BruDeV |
Joined: January 2003 Posts: 1498 Location: San Bernardino, California | Intonation: The nation where Intos live! | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by Beal: Border crossing.What's intonation? | ||
