Josh White... LX neck???
muzza
Posted 2009-02-15 10:28 PM (#427216)
Subject: Josh White... LX neck???
August 2005
Does the Josh White re-issue have an LX neck, ie, removeable?
(I think you can guess where this one's going traitor, I mean Trader.)
While I'm at it, what's the difference between a Josh White and a Folklore? Both are slotheads, both have 1 7/8" nut and both are 12 fretters.
Posted 2009-02-15 10:47 PM (#427217 - in reply to #427216)
Subject: Re: Josh White... LX neck???
The Josh White was renamed the Folklore after Josh died.
Posted 2009-02-15 11:04 PM (#427218 - in reply to #427216)
Not sure about the New Josh White, but my K-1111 does not have any bolts at the 'Neck Block'...
Therefore... If the Josh White is the same, No. I don't believe it is removable.
Charlie Ramon
Posted 2009-02-16 4:18 AM (#427219 - in reply to #427216)
August 2004
Neither the original JW nor the reissue JW have removable necks but wooden neck blocks. Thus performing a neck reset on this guitars is not easy.
Karl
AussieJames
Posted 2009-02-16 4:44 AM (#427220 - in reply to #427216)
June 2007
Yes Muz
The shipping is cheaper if you can remove the neck!!
AJ
Posted 2009-02-16 5:07 AM (#427221 - in reply to #427216)
Oh! I see...
muzza
Posted 2009-02-16 5:20 AM (#427222 - in reply to #427216)
August 2005
Is that the same for the Folklore, then? Non removeable neck?
You're reading me loud and clear, AJ.
Posted 2009-02-16 7:24 AM (#427223 - in reply to #427216)
Anything is removable. I have quite a collection of saws.... :D
Charlie Ramon
Posted 2009-02-16 9:19 AM (#427224 - in reply to #427216)
August 2004
There's a quite simple rule with the early Ovations (including the Folklore). If it has a truss rod the neck is not removable. If it hasn't a truss rod it's equipped with the Kaman Bar and the neck is removable. I think the Folklore never had a K-Bar before it disappeared in the early eighties but I'm not 100% sure.
Karl
Posted 2009-02-16 12:25 PM (#427225 - in reply to #427216)
He's asking about the re-issue. My K1111 RI has a truss rod, or at least a truss rod cover, so I doubt the neck is removable. Assuming the Josh RI is true to it's roots, it would also have a truss rod and wouldn't be removeable, if Karl's simple rule is 100% correct.
Gallerinski
Posted 2009-02-16 12:43 PM (#427226 - in reply to #427216)
The reissues have roughly the same neck attachement as the originals - epoxied in dovetail to a wooden neck block. Although maybe on the reissues they no longer use epoxy, but I'm not sure.
Posted 2009-02-16 2:21 PM (#427227 - in reply to #427216)
I have no doubt that while the design is the same on the reissues as on the originals, the materials used are superior. One example is the finish on the top.....
Gallerinski
Posted 2009-02-16 3:02 PM (#427228 - in reply to #427216)
The strap buttons are much nicer.
