Humidity level
Paulcc1
Posted 2006-10-31 11:17 AM (#233889)
Subject: Humidity level
September 2004
I have a question what would be recommendation for minimum humidity? I have a sensor set at 42% is this good.
Paul
Posted 2006-10-31 11:28 AM (#233890 - in reply to #233889)
Subject: Re: Humidity level
I believe factories try to keep their humidity in the 45-50% range. I have my set to 45% and it tends to vary between 42-48%.
John B
Posted 2006-10-31 12:02 PM (#233891 - in reply to #233889)
January 2004
Anywhere between 40 and 60% should be fine.
Paulcc1
Posted 2006-11-01 12:49 PM (#233892 - in reply to #233889)
September 2004
Thank you!
Posted 2006-11-01 1:55 PM (#233893 - in reply to #233889)
The sensor is called a hygrometer.
Paulcc1
Posted 2006-11-01 4:01 PM (#233894 - in reply to #233889)
September 2004
an4340 posted
Yup thats whay I said a dohickee, whatchamacallit, thingy with digital read out.
Paul
Posted 2006-11-03 10:33 AM (#233895 - in reply to #233889)
This thread made me get off the dime and do something. I purchased a hygrometer last evening at GC at started monitoring. It was 39% in the kitchen when I initially set it. I then placed it at one end of the basement studio and let it set overnight. It read 59% at 63 degrees this morning. If I pile up all the guitars on the stairs halfway between the basement and the kitchen, I should be right in the middle of the sweet zone. 59% is right at the upper end of acceptability according to the directions. If it stays there, I may need to find a humidifier. Any suggestions?
Posted 2006-11-03 10:55 AM (#233896 - in reply to #233889)
If it STAYS there, you'll need a DEhumidifier.
I wouldn't worry about it too too much, unless y'got a bunch of those damned temperamental BOX guitars about . . .
Posted 2006-11-03 11:47 AM (#233897 - in reply to #233889)
Right, Cliff, a dehumidifier. On the other hand, not far from the studio door is my furnace, so I could simply open the door and let the furnace dry it out a bit, at least during the winter months.
