neck adjustment?
dstan
Posted 2005-01-15 1:25 PM (#166320)
Subject: neck adjustment?
I have a Celebrity Deluxe CP2003 LE and its been playing and sounding great, however the action was a little higher than I liked from the 9th to 12th frets. I took one of the shims out of the saddle and that made a noticeable improvement. I replaced the strings and I used Ernie Ball 10s (I use them on my UKII) and I had spaced out picking up some 12s for the acoustic. To make an already long story short, I'm getting the occasional buzz on the strings which is hard to pinpoint. Is it the strings? Should I have tweaked the neck and left the shim alone? Neck adjustments would be a new experience for me. Any advice would be appreciated.
Thanks in advance.
Abendicum
Posted 2005-01-17 5:47 AM (#166321 - in reply to #166320)
Subject: Re: neck adjustment?
June 2004
Most of the Celebs, made in Korea, had the necks Epoxied in place, Making adjustments IMPOSSIBLE... at the heel of the neck... You can "see" the epoxy around the heel if you look thru the sound hole... If you see some black "smuz" liberaly around the "wood" that should be the case... (And NO bolt head)
If you see the "back" of a plastic pocket, which is part of the bowl, and the bolt head which attaches the neck, you can probably remove the neck...
Some of the older stateside ones could be removable, (not sure why no one has jumped in here to help you... So I am putting in my 2 cents)
You might try taking it to a luthier to look at maybe they can find the "buzz"... The only other trick I know of is to find someone with a neck jig fronm Dan Earliwine @ Stewart Macdonald...(I have on and it is one cool tool...) This trick tool will zero out any the defections in the top of the frets, to eliminate that as a source of the annoyant buzz...
AB
dstan
Posted 2005-01-17 8:11 AM (#166322 - in reply to #166320)
There is a thin line of clear epoxy around the base of the neck as seen through the back of the guitar, however the the end of the truss rod is clearly visible with a hex end. What would be the point of a truss rod in the neck if it isn't adjustable??
dstan
John B
Posted 2005-01-17 10:18 AM (#166323 - in reply to #166320)
January 2004
Keep in mind that you are using very light strings for an acoustic. You may want to try a set of 11's or 12's before you start doing adjustments.
dstan
Posted 2005-01-17 12:05 PM (#166324 - in reply to #166320)
Thanks John, I didn't realize a light guage string could cause/contribute to fret buzz. I'll pick up some 12s.
Abendicum
Posted 2005-01-17 8:57 PM (#166325 - in reply to #166320)
June 2004
The neck is still adjustable with the truss rod, on ALL Ovations... you just can't reset the neck by removing it, from the body, for any serious heel/body alignment... Which is what I thought you were referring to when you 1st mentioned "Neck Adjustments",...
Hold the guitar up to a light source and site along either edge of the fret board... There is typically a wobble at the 12 fret as the fretboard comes off the soundboard and goes unsuported as the neck tapers away from the body...This is where compression from the strung neck will show the most...
This is also where most strings will buzz if all else is as it should be... Check also that the nut slots are not cut too deep...
AB
Posted 2005-01-17 9:31 PM (#166326 - in reply to #166320)
I thought the necks were just bolted on, not glued. Shows what I know ...
Abendicum
Posted 2005-01-18 5:13 AM (#166327 - in reply to #166320)
June 2004
Go to page 7 and 8 of the factory manual link, that describes neck adjustment...
http://www.ovationguitars.com/img/OVmanual.pdf
After all this... I think this is what you were after...
Ab
dstan
Posted 2005-01-18 3:24 PM (#166328 - in reply to #166320)
Yahtzee! Many thanks!
dstan
