Got Shims?
| Mitchrx |
Joined: December 2003 Posts: 1071 Location: Carle Place, NY | For those in need of shims here's a suggestion. I was at a local hobby shop this past weekend and found that they had 1/4" X 12" stips of solid brass in thicknesses of .016", .025", .032" and .064". I bought all four for about $3.00. Although 1/4" is a little narrower than the stock plastic shims for the six element piezo saddle, once cut to the proper length they fit very nicely into the stock saddle slot. With the varying thicknesses, I was able to customize the action of my 1619CL to perfection. The thin ones are easy to cut, but I used a jeweler's saw to cut the thicker ones. I also put a very light coating of machine oil on them to make them stick together. | ||
| Tony Calman |
Joined: August 2003 Posts: 4619 Location: SoCal | another suggestion is to cut from a plastic milk bottle... | ||
| moody, p.i. |
Joined: March 2002 Posts: 15682 Location: SoCal | Or cut up your credit cards. Benefits you in more ways than one. | ||
| Mitchrx |
Joined: December 2003 Posts: 1071 Location: Carle Place, NY | I always thought that you would want a dense material for the shims so that all of the vibrations are transmitted efficiently to the top of th guitar. Brass is a whole lot denser than plastic. My guitar sounded fine with the factory shims and I haven't noticed a real sound difference with the brass. What I like is the ability to really customize the action with precision and you just can't achieve that with shims that are all the same thickness. | ||
| willard |
Joined: November 2002 Posts: 1300 Location: Madison, Wisconsin | My 1769 had a strip of the "Ace of Clubs" under one of the stock phenolic shims. | ||
| Old Applause Owner |
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | IMHO, the best material is still at a hobby shop...Evergreen StripStyrene. The 0.188" width appears to be correct for the width of the shim I removed from my 2002 Collectors, and you can get it in .010", .015", .020" and .030" thicknesses. All you need to do is cut the strip to the proper length. Roger | ||
| Steve |
Joined: July 2002 Posts: 1900 | roger, what material is StripStyrene made out of?.. steve | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | styrene. (the plastic they make model cars out of) | ||
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | Yes, it is polystyrene....meant for scratchbuilding model parts. Roger | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | . . . and giving pre-pubescent young lads their first healthy "buzz" . . . . | ||
| cruster |
Joined: May 2004 Posts: 2850 Location: Midland, MI | No, cliff, that was the glue, not the styrene. But, I thought they changed the formulation so you couldn't get buzzed anymore. Or maybe that's just urban legend.... | ||
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | cruster, there are TWO formulations.....one smells like citrus and won't hold much of anything, and then there is the "nasty smelly" stuff that actually WORKS. Roger | ||
| cruster |
Joined: May 2004 Posts: 2850 Location: Midland, MI | IIRC, the active ingredient was toluene, no? Or maybe it was one of the others. I think I burned those brain cells out putting together models. ;) I hated planes the most...the canopies always got stringy glue stuck on them. =( | ||
Got Shims?
