Breadwinner / AD-II CL pickup question
Posted 2004-12-09 1:25 PM (#170388)
Subject: Breadwinner / AD-II CL pickup question
The guitar input on my Korg PXR4 recorder has a HI and LO setting. They discribe low output as a single coil pick-up. Are the first generation pickups in my Breadwinner concidered hi-output?
How about my AD-II with the OP-Pro?
Thanks.
Posted 2004-12-09 3:57 PM (#170389 - in reply to #170388)
Subject: Re: Breadwinner / AD-II CL pickup question
check the manual, Hi & Lo could refer to either input sensitivity or input impedance, which are very different. If it refers to impedance then both guitars have high-impedance outputs. If it refers to sensitivity then you'll need to experiment to find the position that produces the best signal-to-noise ratio without clipping the input stage
Posted 2004-12-09 4:12 PM (#170390 - in reply to #170388)
Thanks Paul.
Basicly the manual says try one way and if that don't work try another. I'll keep playing around with it.
