When your record, do you use a mike too?
gordholio
Posted 2004-06-21 9:42 AM (#184636)
Subject: When your record, do you use a mike too?
October 2002
Hi guys:
Sometime this week, I'll finally receive the 2003 Ovation Collectors Edition guitar I ordered a couple weeks back. I'm just wondering - what do you all use when you record your Ovations? Are the pickup systems good enough on their own or do you mike your guitars as well? I figure the OP40 system in my Ovation is supposed to be pretty danged good.
gordo
Stevechapman
Posted 2004-06-21 10:00 AM (#184637 - in reply to #184636)
Subject: Re: When your record, do you use a mike too?
April 2003
Gordo,
actually it's not uncommon to see People Record Ovations Plugged in and mic'ed as Well. Miles and Paul T could give you some good technique/Mic Placement when you record. Just EQ adn Pan your signals slightly to the right and to the left. You'll be amazed with the sound.
Posted 2004-06-21 10:57 AM (#184638 - in reply to #184636)
Personally I never record with pickup only. There isn't a pickup yet that sounds as good as an OK microphone. I occasionally mix a little of the direct sound with the miked signal but usually I use a pair of good condensers, either AKG414 or Rode NT3. Having said that, if the guitar is in a band mix with bass, drums keyboards & electric guitars then you can usually get away with direct-only, but for solo guitar & voice or acoustic ensembles it's got to be mikes.
gordholio
Posted 2004-06-21 10:59 AM (#184639 - in reply to #184636)
October 2002
I have an SM57, SM58 and a condenser mic, so I can use any of those. I will freely admit though, that the main reason I got the Ovation is for its plugged in sound and therefore the ease of recording. Ovation's had so much experience developing an excellent plugged in sound that I hope I can use *just* the plugged in sound if I want to without it sounding too thin. But if miking only adds to it, I'll happily do both.
gordo
Posted 2004-06-21 2:40 PM (#184640 - in reply to #184636)
I'm with Paul on this. If you really want to get the "sound" of any guitar, you need microphones. However, depending on the mix, sometimes just the onboard pre-amp is fine. I always record the pri-amp, and mix it in. The pre-amp picks up a lot of detail that can be useful in making a great end result sound with the mic's.
