Can I just switch?
ahorsewithnoname
Posted 2003-02-28 2:25 PM (#211691)
Subject: Can I just switch?
February 2003
My Celebrity has the OP11. Can I just pop it out and put in the OP24? If so how much do they cost? Thanks..
Posted 2003-02-28 6:18 PM (#211692 - in reply to #211691)
Subject: Re: Can I just switch?
All the new pre's except the OP50 which uses a balanced & unbalanced out are supposed to be interchangeable. Some of the entry-level preamps are passive, so they would need a differnt output jack.
ahorsewithnoname
Posted 2003-02-28 7:38 PM (#211693 - in reply to #211691)
February 2003
So, what you are saying is that I can push the little release button, take out the little OP11, and just snap in the OP 24 and thats all? Sounds too good to be true. Is this correct?
Posted 2003-02-28 9:15 PM (#211694 - in reply to #211691)
Some of the entry-level guitars have passive preamps (no battery) It would appear that all others are interchangeable except the Op50, which is the only pre which uses an XLR and a jack output. The OP24 is an older model & is a different shape to the current preamps
