Bass Bridges
Diego
Posted 2011-05-23 6:04 PM (#1529)
Subject: Bass Bridges
May 2011
Hello
Ive recently purchased an Ovation Typhoon II. I was wondering if anyone knows if there is a bridge replacemente that would fit as im finding the action to be too high
thanks
BruDeV
Posted 2011-05-24 2:27 AM (#1530 - in reply to #1529)
Subject: Re: Bass Bridges
If I remember correctly, there is a neck tilt adjustment that is located under the neck plate.
Note: the screws holding the plate are not the screws holding the neck.
you'll need to loosen the neck screws a little to use the tilt screw.
Posted 2011-05-24 10:24 PM (#1531 - in reply to #1529)
What BruDev said.. as long as the neck isn't toast, a touch of those screws should do it. Also don't go to heavy on the string gauge as that tends to pull the neck.
Diego
Posted 2011-05-25 11:55 AM (#1532 - in reply to #1529)
May 2011
Hey!
Thanks a lot for your answers.
Im not shure i completely understand though, sorry.
The thing is, i find the strings to be too high from the neck. i was thinking of putting a shim under the neck, but form what i understand from your posts, this won't be necessary with this tilt? How does it works?
thanks again
Posted 2011-05-25 2:32 PM (#1533 - in reply to #1529)
Diego, try posting in the main forum for more answers
