Low (no) string squeak?
dweezil
Posted 2009-10-04 4:16 PM (#395647)
Subject: Low (no) string squeak?
Can anyone recommend strings that help eliminate string squeak for recording purposes
YES I know I need to improve my technique!
YES I know I might be able to edit out the squeaks!
YES I know I could 'ask' Google but I value your actual knowledge/experience!
YES I know you like certain strings for whatever reason but the question is there a particular type of string that might be less susceptable to string squeak?
Currently I use Elxir Nanowebs.
Jonmark Stone
Posted 2009-10-04 4:28 PM (#395648 - in reply to #395647)
Subject: Re: Low (no) string squeak?
I won't get into the string debate... I will say, as a player and engineer, I've come full circle with this from a recording standpoint.
String chirp, of course within reason, is a part of the sound of an acoustic guitar being played, and for the most part, it's no longer my aim to eliminate it in recordings.
Just one man's opinion though.
Posted 2009-10-04 4:58 PM (#395649 - in reply to #395647)
You can try D'Addario EFT16's (Light's ... I think they're also available in other gauges). They are polished flat tops designed to reduce finger noise, especially made for recording. But they won't eliminate all squeaks but definitely will help reduce them.
Posted 2009-10-04 9:31 PM (#395650 - in reply to #395647)
Elixir strings are a lot quieter than non-coated. There are some slippery concoctions which can be applied to strings which do a good job of making them quiet, such as finger-ease.
dweezil
Posted 2009-10-05 3:17 AM (#395651 - in reply to #395647)
Thanks. I'm of the same mind as Jonmark, I think that the scrapes give my recordings a human and 'honest' feel.
Will try and reduce by improving my technique however.
