I hate the sound of my Ovation
Darkbar
Posted 2009-08-30 2:07 PM (#400558)
Subject: I hate the sound of my Ovation
January 2009
(Ha!...I knew that would get you)
I hate the sound of my '99 Collector's plugged in. It sports the Optima pre-amp. I play it through a Fender Acoustasonic SFX-II. No matter what I do with the settings, it either sounds quacky, dull, or flat. My '77 Takamine with an aftermarket Martin thinline, no pre-amp, sounds better than the Ovation. Are the new systems that much better, or do I have a tin ear. When I played g8r's Adamas plugged in at the seacow serenade, it sounded sooooo sweet. So what's up?
G8r
Posted 2009-08-30 2:56 PM (#400559 - in reply to #400558)
Subject: Re: I hate the sound of my Ovation
It sounded "thin" to me, too, and I couldn't quite adjust it to my liking. I don't know if it's the Thinline pickup vs. the Original Patented pickup that makes the difference, or the Optima, or both. I only owned one O with a Thinline, and it was coupled to an OP24. I don't recall being disappointed with that one plugged in. Short of sending it to Mother to have them put in a regular pickup and newer pre-amp, I think you're limited to either a good mixing board, a pedal EQ, and/or really good EQ circuitry on an amp, like the Alesis on some Genz-Benz.
Jonmark Stone
Posted 2009-08-30 3:15 PM (#400560 - in reply to #400558)
A personal opinion... I wouldn't blame the Optima. The O thinline PU's are thin and brittle to my ear.
YMMV
Posted 2009-08-30 4:01 PM (#400561 - in reply to #400558)
+1. It's more likely the pickup than the Optima, which imo is the best preamp up till the Studio.
Posted 2009-08-30 6:32 PM (#400562 - in reply to #400558)
Unless the preamp is faulty it's not down to the Optima, which is one of Ovation's best. A pickup system can only reproduce what it's given by the guitar. If the guitar sounds good acoustically (given that it has a plywood top) then it should sound good plugged-in. Maybe the thinline pickup is kaput.
Darkbar
Posted 2009-08-30 7:42 PM (#400563 - in reply to #400558)
January 2009
Actually, before I bought the Ovation, and before I had the thinline installed on the Tak, I had a Dean Markley soundhole pickup on the Takamine...it also sounded better than this Ovation thinline! If the pre-amp is so good, can't I get the thinline pickup that came with the Ovation changed out with something better?
Omaha
Posted 2009-08-30 9:04 PM (#400564 - in reply to #400558)
I had the thinline/Optima combo on my 1597 Adamas. I had the same complaint about the tone...very edgy and brittle sounding. I agree with the consensus here that its the pickup and not the pre-amp.
