Ovations with a wider neck
Beach RPh
Posted 2013-02-07 11:15 PM (#465033)
Subject: Ovations with a wider neck
October 2012
Hello all!
After beginning to learn to play better on my new ovation I have determined that my chubby fingers might do better on a guitar with a wider neck (or nut I believe). Any suggestions of models I should look at?
Thanks,
muzza
Posted 2013-02-08 12:07 AM (#465035 - in reply to #465033)
Subject: Re: Ovations with a wider neck
August 2005
Ute (an Adamas)
Josh White
Folklore
2008 Collectors (also an Adamas)
or go Classical.
bburg
Posted 2013-02-08 2:34 AM (#465042 - in reply to #465033)
August 2009
2009 Collectors
1680 (Adamas)
1682 (Adamas)
FD-14.......
TAFKAR
Posted 2013-02-08 5:47 AM (#465048 - in reply to #465033)
Also, Lost Art Koa. See here: http://www.lostartvintage.com/Categoryinfo.aspx?categoryid=8&catego...
Posted 2013-02-08 7:38 AM (#465052 - in reply to #465033)
Or, more arcane --> Academy KA-17
Posted 2013-02-08 9:44 AM (#465055 - in reply to #465033)
And the 97 collectors
Posted 2013-02-08 10:55 AM (#465058 - in reply to #465033)
A few of the OFC2 guitars
bburg
Posted 2013-02-08 11:53 AM (#465059 - in reply to #465033)
August 2009
.....and the OFC 1 guitars, too.
DanSavage
Posted 2013-02-08 1:11 PM (#465061 - in reply to #465033)
Subject: RE: Ovations with a wider neck
June 2012
1624 Country Artist
Beach RPh
Posted 2013-02-08 4:53 PM (#465076 - in reply to #465033)
October 2012
All lovely guitars, guess I will be saving my pennies for a while. Some of them are only 1/16 wider than my 6868, others are 3/16 wider. Will have to try out some wider nut guitars in my local store to see if I can tell the difference before buying.
Thanks for all the responses!
Posted 2013-02-08 5:02 PM (#465077 - in reply to #465033)
Dave, You would be surprised how much difference a 1/16" can make.
I have a Hamer solid-body electric....
It has a standard 1-11/16" nut, just like my Ovations...
But it FEELS wider!
I finally got a Caliper an measured it...
The nut is 1-11/16" but the string spacing from E to e is wider.
So those little measurements don't sound like much, but you will feel the difference.
muzza
Posted 2013-02-08 6:44 PM (#465085 - in reply to #465077)
August 2005
DanSavage - 2013-02-09 4:11 AM 1624 Country Artist
Country Artists are nylon string aren't they?
arthurseery - 2013-02-09 8:02 AM Dave, You would be surprised how much difference a 1/16" can make. (.....). So those little measurements don't sound like much, but you will feel the difference.
Agreed. TAKAR's '08C's nut width is only 1/16" wider that my '05C but it feels like 1/4"!
muzza
Posted 2013-02-08 6:46 PM (#465086 - in reply to #465033)
August 2005
If an OLD Folklore 1114 comes to the surface, grab it! Unless you need a cutaway.
Nordicnorm
Posted 2013-02-09 2:48 PM (#465112 - in reply to #465033)
May 2010
If you capo on the second fret, you are pretty close to the spacing on a 1-3/4 neck (nut). Should give you anidea. I have big hands and fingerpick. Have owned an old Folklore for ayear. That is a very wide neck (1-7/8), but playing it has improved my left hand dexterity and fingerplacement on the standard necks (I have several)so much that I no longer yearn for something wider (for me maybe 1-3/4 would be nice).
A nut with 1/16 more spacing would bring the strings 1/32" closer to the edge on each side. OMA is right, the difference is quite notisable, and I don't think it would present a problem. Worked great on my Trekker (narrow neck fitted with a standard O nut).
Beach RPh
Posted 2013-02-09 3:40 PM (#465118 - in reply to #465033)
October 2012
Thanks for the suggestion Nordicnorm, will try that.
Posted 2013-02-11 2:35 PM (#465181 - in reply to #465033)
+1 1624 Country Artist
