Refinishing a top? Suggestions? :confused:
tjmangum
Posted 2008-02-20 3:14 PM (#53750)
Subject: Refinishing a top? Suggestions? :confused:
Hi,
Just picked up a 1624 Country Artist model and it had, at one time, some kind of funky swirly decal across the top (seems I have seen this before) There is glue residue and shadows in this pattern and I wonder what might be the best way to fix? Can I take a real fine sand paper to it, thinner or is this best left to a pro to strip and redo?
Any suggestions would be appreciated.
Thanks!
tj
Steve
Posted 2008-02-20 3:21 PM (#53751 - in reply to #53750)
Subject: Re: Refinishing a top? Suggestions? :confused:
July 2002
Don't use sandpaper. Take a very soft cloth and put a small amount of rubbing alcohol on the cloth first, then lightly wipe the surface. Most any kind of thinner will tend to dissolve the polyurethane, don't use thinner.
Posted 2008-02-20 3:45 PM (#53752 - in reply to #53750)
tj,
Welcome to the OFC. You've got a great guitar. I would tend to agree with Steve. Go slowly and you should be able to remove all the residue. Ovations have a pretty durable finish.
BTW; Both Steve and I, along with a lot of other members have this model guitar.
Mitchrx
Posted 2008-02-20 3:51 PM (#53753 - in reply to #53750)
I'd try Goo Gone. It's natural and supposedly doesn't have any harsh chemicals. Just don't leave it on too long. Goo Gone
Posted 2008-02-20 4:12 PM (#53754 - in reply to #53750)
Naptha (lighter fluid) will remove it.
tjmangum
Posted 2008-02-20 6:03 PM (#53755 - in reply to #53750)
Thanks to everyone - I'll try some of these fixes and let you know.
Cheers,
tj
tjmangum
Posted 2008-03-07 1:33 PM (#53756 - in reply to #53750)
Well, I tried both the rubbing alchohol and the Naptha with no luck. It must have been ingrained into the finish. Once the weather gets a little more consistent in a month or two here in N. California, I will take to my guitar guy and see if he can do an affordable fix.
Am having fun with it, great sound plugged in.
tj
Posted 2008-03-07 3:41 PM (#53757 - in reply to #53750)
If it's on the surface of the finish keep rubbing with the Naptha. If it's damaged the finish then try meguire's scratch x.
Paul Blanchard
Posted 2008-03-08 7:49 AM (#53758 - in reply to #53750)
Stickers that have been on guitars awhile can leave 'sticker shadow' when removed. It's due to the differential effects of light. Really good polishing with a scratch remover can even the surface, but it takes time for the differences in color shading to even.
