Tuning Down GC1618
Folkestone
Posted 2008-01-27 10:55 AM (#58212)
Subject: Tuning Down GC1618
June 2007
I need to rely again on the advice of you seasoned experts.
I've got a 1981 GC1618 12-string. As you know it is only 12 frets to the body and in excellent condition, kept humidified in-case, etc., etc.
Do I need to tune it down to prevent below0bridge-heaving (BBH)? At 26 years of age plus you have to reallylook and feel for any heaving.
Jeff
FlicKreno aka Solid Top
Posted 2008-01-27 11:09 AM (#58213 - in reply to #58212)
Subject: Re: Tuning Down GC1618
I suggest something Light , I use Martin M170 gauge 10 - 47 , allthough them are just 80/20 bronze , they last reasonably long , and have a " chimey " sound , great on a 12 stringer , as far as that " belly -up " U`re mentioning , that happens to most ( all ) 20 plus yrs. guitars , many feel that it improves the sound.
Tuning down/differently should depend on the music U play , not the quality of the guitar .
Vic
..try not to worry , have fun instead..
Posted 2008-01-27 1:26 PM (#58214 - in reply to #58212)
Never had a problem with any of the 12 fret slot 12 strings, that I've owned, with the neck or the top. They are probably the strongest in existence, except for the Adamas line.
Posted 2008-01-27 2:53 PM (#58215 - in reply to #58212)
You probably do not have to tune down an Ovation. Years ago earlier model 12 strings from other manufactures recommended it. I do it and use a CAPO. :D
Posted 2008-01-27 5:52 PM (#58216 - in reply to #58212)
CG : You probably do not have to tune down an Ovation. Years ago earlier model 12 strings from other manufactures recommended it. I do it and use a CAPO
But even setting the action higher to avoid stringbuzz , the strings could still " clang " against each other , How do U do it ( replace strings often ? Heavy gauge ? )..?..secrets on the table please :)
Vic
Posted 2008-01-27 6:47 PM (#58217 - in reply to #58212)
I use light,(.010-.047), strings, tune to "D" and I don't use a pick. I have tried heavier gauge strings on my 12 strings but didn't like the feel. Note; I do use heavier,(.011-.052) on my 6 string guitars with good results. The action on my guitars is standard or a little higher.
If I do strum too hard the sound isn't as clean which may be caused by the strings hitting each other although i don't think so. The group i play in a church does a lot of stuff in Bb,Eb and F. So tuning down allows me a lot of options such as when playing in F I can capo up to the third fret and play in E, or remove the capo and play in G,(Rumble) :D .
Posted 2008-01-27 7:15 PM (#58218 - in reply to #58212)
That`s Sound thinking :)
Vic
