need info on packing for shipment
Thanksforallthefish
Posted 2005-02-16 4:42 PM (#163144)
Subject: need info on packing for shipment
I am packing a 12 string for shipment within the U.S.. It will be in an Ovation HSC and then peanut packed within a cardboard shipping carton. Should I fully detune/slack the strings or just drop them down a couple of steps.
sorry newbie at shipping... like getting guitars, hate getting rid of them.
Thanks,
Glenn
God Bless
Islander
Posted 2005-02-16 4:46 PM (#163145 - in reply to #163144)
Subject: Re: need info on packing for shipment
October 2004
I usually slack the strings when shipping,especially in winter weather.
Thanksforallthefish
Posted 2005-02-16 5:01 PM (#163146 - in reply to #163144)
slacked and packed.... auction closes in 5 minutes
thanks to all that bidded
god bless,
Glenn
Posted 2005-02-16 5:01 PM (#163147 - in reply to #163144)
Been there, done that, learned from Al!
Lighten up the strings but not totally - I go with DD GG DD GG BB DD for a 12. This is Open G (on Gsus for us church band people).
Ovation case that fits and pad just under the headstock with paper, towel or better yet bubble wrap.
Use a guitar shipping box - GC's back door has piles of them. Put extra cardboard to pad in front, back and the sides. Balled up newspaper is better than the popcorn crap cause it stays in position. Pad the bottom of the box and then put the guitar and case inside. Pad over the top before closing the box. Use the clear packing tape instead of masking or duct tape.
Remove all previous addresses or GC gets a new 12 string they won't know where to hang!
Thanksforallthefish
Posted 2005-02-16 5:03 PM (#163148 - in reply to #163144)
Thanks Mwoody using your method... already had nice shipping box from howie.
God Bless,
And thanks all.
Glenn
Wuzhizzoner
Posted 2005-02-16 5:03 PM (#163149 - in reply to #163144)
Maybe you should put DO NOT STACK ANYTHING ON TOP OF THIS BOX ... on it!
Brian T
Posted 2005-02-16 5:24 PM (#163150 - in reply to #163144)
Call me a fanatic, But I have shipped numerous guitars without a problem, but my methods are a bit extreme:
(1) partially detune, maybe about 1/2 the tension.
(2) Wadded newspaper or bubblewrap under the headstock filling open the space.
(3) The entire case goes into a large lawn-leaf garbage bag and gets taped shut - this is in case of water damage but also keeps the packing peanuts away from the guitar case, having to pick fragments of styrofoam off of a new case just pisses people off. The bag also helps keep the humidity stable.
(4) I then tape a layer of foam or bubblewrap to the tip and bottom edge of the case (outside of the grabage bag), in case it gets dropped on it's end.
(5) I fold two cardboard triangles (with the grain) the exact thickeness of the box, kind of like little pillars, then tape these to the case (outside the garbage bag)where the bouts narrow. These help should something heavy be placed on the flat side of the box and also keep the case centered in the box sideways.
(6) I then slide the whole mess into a guitar box and fill with packing peanuts.
When the buyer gets it he can slide it out and just cut the garbage bag off and toss the mess in the trash, the case will be clean and dry. I know it's a bit extreme, but I have shipped several high end guitars and never had a problem.
Posted 2005-02-16 5:39 PM (#163151 - in reply to #163144)
Heck, when Guitar Center gets an Ovation, we know they don't know where to hang...unless it is high enough to get cobwebs :rolleyes:
Brian T
Posted 2005-02-16 5:51 PM (#163152 - in reply to #163144)
Oh yes, say what you want about their guitars, but Taylor makes the finest shipping boxes in the business, I have scrounged a few of them from GC. You could ship spent fuel rods in those things and they would be perfectly safe.
Posted 2005-02-16 6:00 PM (#163153 - in reply to #163144)
beware the taylor boxes are double oversized and ship at 70 lbs
been there done that
Posted 2005-02-16 6:02 PM (#163154 - in reply to #163144)
I've shipped spent fuel rods before. Let me turn that one in for cost savings!
I am probably too late at posting for Glen but there has been some great discussion and tips in the archive!
Thanksforallthefish
Posted 2005-02-16 6:25 PM (#163155 - in reply to #163144)
Kind of a bummer letting her go,
but seeing the others post up on ebay after mine listed at least gives me some hope that I will find another to stand in for her when we're a little more solid here.
thanks all for the support and tips and yes, I should have checked the archives but trying to avoid the SEARCH issue here on the site.
thanks again and god bless,
Glenn
Paul Blanchard
Posted 2005-02-17 9:53 AM (#163156 - in reply to #163144)
IMHO, take all tension off the strings. The strings pull on the top, and increased pull on the top is likely to increase vulnerability to the impact cracks to which Ovations are prone. If the carton allows it, add all extra protection to the face side of the case to prevent impact. Don't worry about the bowl side.
FWIW, I have shipped hundreds of Ovations and many of them globally. I do know a bit about this topic.
AL
Posted 2005-02-17 11:21 AM (#163157 - in reply to #163144)
Check out - 'www.frets.com' - Frank Ford has a section of his website that has instructions with great pictures on how to correctly ship or travel with a guitar anywhere in the world.
Enjoy
Alan
